Lotus notes in my computer is not configured
I installed a Lotus Notes in my new computer, but it was not configured. What should I do in order to set up Notes?
Hello Rebecca,
Please follow the instructions below to configure your Lotus notes.
Configuring Lotus Notes
Launch Lotus Notes by choosing Start > Programs > Lotus Applications > Lotus
*You will notice that the Lotus Notes Configuration will show in your screen like the picture below. Click next>
Then type in your name in the “Your name” box, and then uncheck the “I want to connect to a Domino server box”. Click Next>.
Make definite that none of the boxes are checked in this part and then click Next>.
You can go back to the previous windows if you want to change in your settings by clicking “Previous” the after that, click “OK” when the Notes setup is complete.
Lotus Notes will now open the Welcome page with Notes 6 setup options. Click on the “No thanks, just give me the defaults option”. However, it depends on you if you want to change more settings. Afterward, you will contain the Lotus Notes default Welcome page on the screen.
I hope this was help!
