Waall Mike
270 points
Posted on - 10/13/2016
Lotus notes are used to store the large data of a firm. A business uses it for communication between the members and organizes the messy data. How lotus notes to SharePoint migration done?
Jo Anna
Lotus Notes To Sharepoint Migration For Using More Features.
We can use Migrator to migrate the application contents from Lotus Notes to the SharePoint.
It allows us to migrate the contents of simple as well as complex applications.
It reduces the cost and risk of migration
PROPERTIES:
1) It analyses the data complexity along with design, identifies the inactive applications that do not require migration, and identifies those that need development resources. This analysis helps to manage the notes.
2) It automatically provisions new sites depending on the infrastructure.
3) There is no fidelity loss during the migration. You can save all the important information. Document and HTTP links can be maintained. This is done by redirecting the users to the current position in every document irrespective of the migration.
4) You have options for application migration to get the best business objectives.
THE MIGRATION CONSOLE
ANALYSIS BEFORE MIGRATION
CLASSIFICATION DONE AUTOMATICALLY
ANALYSIS OF DESIGN
REPORT
EASY MIGRATION
SYSTEM REQUIREMENTS:
Windows Vista SP2, Windows 2012, Windows 7 SP1, 8, 2008 R2, 2008 etc.
The version of lotus notes must be 8.5.3 and greater.
.NET framework version 3.5 and 4.0 are necessary.
Any version of SharePoint installed.
