Lotus Script Extension Error when creating an agent
I have made agent which using the Lotus connectors Lotus Script Extension in connecting to a DB2 table. But I am just getting an error message which displays that ‘error creating product object’. I don’t know what is happening. Please help me to figure out the problem. Thanks in advance.
Answered By 0 points N/A #90976
Hannah,
 Hello to you. If the possible code that connects to DB2 runs on the Lotus Notes client, you need a DB2 client installed on every Lotus Notes client machine. It's better to try to design the application so that it only needs DB2 connection from the Domino server Because that's not a common problem it just only mean that the interface to DB2 cannot be loaded.ot  the Path statement is wrong that's why the DB2 DLLs cannot be loaded.All you need to do is to re-install the DB2 client and make it correct. Use the DB2 client functionality to connect to a DB2 server .Which you will need to do to catalog on  the DB2 database to be used or you'll get an error when you try to connect to it. The very act of cataloging it shows the DB2 client is installed; if at the end of cataloging a database you can test-connect to it, the client works.
