marjuk
Posted on - 10/07/2011
Lotus notes is so old invention in software period and changed the company name also from Lotus Development Corporation to IBM. Then it has changed dramatically but I have a question about this. Is Lotus support the high screen resolution like 1027*768 properly?
Lotus is one of the greatest relational database systems that provide various areas of applications and tools. Yes it is now under the IBM control. But now it has great new release versions such as Lotus 8.5. It has lot of new and fantastic applications, plug-ins and tools. It will support to the high resolution very well.
New releases are more accurate and more compatible. They support vast area of Operating Systems and other applications.
Yes it will support to the high resolution very well. For a example I use it with 1027*768 resolution myself.
It says the minimum screen resolution for Lotus 8.5 is 1027*768 in system requirements
