Lotus Symphony 3 error message
My laptop is Lenovo ThinkPad T420 graphic card “Nvidia Optimus".
I installed Lotus Symphony 3 and there was no problem in installing but when I launch it I got this error message:
The application cannot be started.
The content manager is not available.
Start the setup application to repair the installation from the CD or the folder containing the installation packages.
So please anyone tell me why this error happened and how to fix.
Answered By 0 points N/A #92554
IBM Lotus Symphony 3 contains fixes for a few critical security vulnerability issues and other low risk, high impact fixes.
First off all uninstall the software and reinstall the software by this method and follow the instruction given below.
Uninstallation instructions
1.Locate the Lotus_Symphony3_fp3.exe file in the folder where you downloaded the fix pack.
2.Double-click the Lotus_Symphony3_fp3.exe file and follow the wizard to complete the uninstallation.
To install using a GUI:
  1. Download Fix Pack 3 to a folder on your hard disk.
  2. Double-click the Lotus_Symphony3_fp3.exe file and follow the wizard to complete the installation.
  3. To verify that the installation is complete, click Help > About IBM Lotus Symphony and notice that the release number is changed to 3.0.0 FP3.
To force installation:
  1. Download Fix Pack 3 to a folder on your hard disk and open a command window.
  2. Enter the following command: Lotus_Symphony3_fp3.exe /s /a /s /v"HOTFIXACTION=INSTALL".
To install in silent mode:
  2. Enter the following command: Lotus_Symphony3_fp3.exe /s /a /s /v"/lv c:installogs.txt HOTFIXACTION=INSTALL /qn"
 I hope your problem has been resolved now :))
