Loud noise fan problems in computer
Hi there!
My office computer fan makes very loud sound noise. It is very boring for me. At last I have been deciding stop this fan. But if I stop CPU fan so my processor will be risky.
Thanks
Hi there!
Thanks
Fans located inside the pc, are working to dissipate heat from the pc. These fans sometimes make louder noise because they are getting over heat, which they cannot dissipate completely. You can do two things to solve your problem.
1. You can solve your problem by placing your fan at some cool place. By this the pc will not get more heat and your problem will be solved easily.
2. If you cannot change the place of your pc. Then change the fan and put there more powerful fan. If your power supply's fan making problem. Then you need to change whole power supply, because changing only the fan of power supply is not recommended.
By following any of the above solution, you can easily solve your problem.
