Low bandwidth problem in my Android device during calling.
Hi Experts,
I am having a problem of low bandwidth android calling device. I am so embarrassed due to this problem.
Does anybody knows the possible ways to simulate the bandwidth. Please Help
Answered By 0 points N/A #193342
Hey Fox,
Since you did not specify your android model I cannot make sure if it is a hardware problem. Try turning off your 3g while making a call. If that helps then the problem would be from your carrier.
Call your carrier and tell them that you are having such a problem. They will most likely ask you to reset your 3g settings.
Answered By 590495 points N/A #305391
I’m not sure if you are referring to the signal or internet speed. Anyway, if you are calling someone but the signal is very weak, this might result to poor audio when the person on the other end starts talking. You may also hear some breaks or gaps between the conversations. To avoid this from happening, transfer to a different location where there is good signal.
If you are inside the house, try going outside so your phone can receive strong signal. You may also try moving near the window. In worst cases, when your phone receives very weak signal, your call can be cut off any time. Since mobile phones are wireless, it depends on the strength of the signal to establish a call. Frequently, phones with low signal can’t receive calls.
