gmhossain
30 points
Posted on - 11/14/2012
What do you think about "low format flash drive Toshiba" ?
Do you think it is a good flash drive?
“low format flash drive Toshiba”
Negative Side of low format flash drive Toshiba:
1. Can't read, write, or format
2. Often sometimes doesn't display in window as a separate removable drive as though the PC detects its existence.
3. Sometimes this dialogued shows – Windows says "Drive is not formatted. Format now?"
4. Saving any word document may result bad sector spotted at flash drive and next day it may not open properly.
5. Sometimes it doesn't shows any files or folders in the drive and remains all files and folders hidden or may be sometimes result write protected all files and can't delete any files from flash drives.
So my suggestion is low format flash drive Toshiba is not suitable for any rough workings for all users.
