nunoz4life
10 points
Posted on - 08/06/2011
I have a smartphone with an android as operating system. Type of my phone is Samsung Galaxy 551. I have already installed few applications and it sometimes says my internal memory was low. I have already installed app2sd and moved some application to external memory but it still shows. Can you help me, how to solve this?
Linkman
Low memory internal notification android
Generally, samsung Galaxy 551 is having limited internal memory and the applications that you have installed directly copied here. These causes not only slow down your phone, but also many error messages might come saying that your memory is low. If the case is worse, you will not be able to get the messages even.
One of the most possible solutions for this is to install all your additional applications to the external memory (SD card) as you have already done. Other option is to take the admin rights of the phone (rooting) and this enable you to arrange the system files of the phone in your own way arranging more space. However, you have to be careful when you do the rooting, as this may mess up all if you are having lack of knowledge and experience. Other way is that you can give adb (Android Debug Bridge) commands to communicate with the devise in a way that you can arrange more space in the memory.
Cheers
Fowler
