Hi everyone, Today i've got a problem with my browser Mozilla firefox. I'm using the latest version of Mozilla firefox. But i'm not getting sufficient speed.
I've followed some tricks to increase the speed but in vain. Any tips?
Thanks in advance.
Low speed of Mozilla firefox
You just need to clear the downloads list, removing old Java Consoles, and switching to newly opened tabs.
then you problem will solve
If this is the first time that this happens with your web browser, try closing the web browser, restart your computer then try it again. See if there is an improvement on the speed after rebooting the system. The speed of the web browser is sometimes affected by too much processes running on your machine that makes the processor very busy and processing the information on the web browser tends to become very slow even if you are using a fast connection.
You can view the running processes from the Windows Task Manager by hitting CTRL + SHIFT + ESC on your keyboard or alternatively by CTRL + ALT + DELETE. You can see graphically the performance of the processor from the Performance tab while in the Processes tab a much detailed information is displayed on which application is taking too much processing. Be very careful not to terminate running applications that are essential to the system. Terminate only those programs you know and you are sure are not needed.
Mozilla Firefox is a most popular browser. It is faster and better quality. Sometimes it can be slow. There are different reasons for slow down the speed of Mozilla Firefox. This problem can be occurred by some issue-
You should check your favorite. Large number of favorite slow down the Mozilla Firefox. So, you should delete your unimportant favorites from Mozilla.
The largest number of toolbars are a reason for the slow down Mozilla.
If a virus attacks your Mozilla then it may be slow down.
You should check your troubleshooting problems. Malicious might be block your browser.
You can find more information and tutorial.
