LPR Port Configuration Warning Error
Hello everybody!
The error message that appears to me is:
LPRÂ Port Configuration Warning
The LPD Server did not respond as expected to a test command.Â
Any of the following can cause this error:
The entry for IP Address or Queue Name is incorrect.
The TCP/IP print device (LPDÂ server) does not support the
test command.
The specified TCP/IP print device is not available.
If the information typed in the previous screen is correct, you can
ignore this message. Click OK to continue, or click Cancel to return toÂ
the previous screen and verify settings.
                                   OK        Cancel
I have a problem related to printers and I am interested to know its solution. I wanted to set up at test environment to programmatically set up the ports of LPR, to a queue on a Unix system for Windows (however I use Ubuntu for testing in a virtual environment).Â
I want to send the print from Windows to Ipd:\192.168..xqueuename that is configured for me in CUPS on an Ubuntu machine that is set up to go back to the Windows-system that has a (Samsung) printer connected to USB, but shared on the environment (a different queue than that one initially started the request).Â
I am not allowed to use Samba, or any other printing protocol from Windows than LPR/LPD through destination port 515.
Any help?
