LRP Port Configuration Warning Error
I want print some documents by using printer but I am receiving port error. I configure ports but I can’t remove error. Please tell me this is printer error why here TCP/IP issues. Also tell me its solution how can I remove this error.
The LPD Server did not respond as expected to a test command. Any of the following can cause this error:
The entry for IP Address or Queue Name is incorrect.
The TCP/IP Print device (LPD server) does not support the test command.
The specified TCP/IP print device is not available.
If the information typed in the previous screen is correct. You can ignore this   message. Click OK to continue, or click Cancel to return to the previous screen and verify settings.
        OK     Cancel
