effieclyde
10 points
Posted on - 05/30/2012
I’ve heard Lunascape 6.7.1 claiming to be the most versatile web browser of the world. Does anyone have experiences of using it? From which browsers the plug-ins and add-ons are imported? This information is important to know before I can say it’s going to be the best.
Lunascape 6.7.1 most versatile browser
Hi
I am using Lunascape 6.7.1 and for me it works perfect. There are sites that will work best with Internet Explorer while most of my researches are using Google Chrome. It’s a bit hassle on my part switching from Internet Explorer to Google Chrome from time to time so I decided to try Lunascape 6.7.1. The browser is perfect for me. Lunascape have this compatibility advantage than Internet Explorer, Firefox, or Google Chrome.  I can now use one browser all the time. Lunascape 6.7.1 have new features like bookmarklets, it supports scripts for more advanced automation tasks, also includes mouse gestures, plus a pop-up blocker and built-in RSS reader, allowing you to set the user agent string, and is generally very easy to configurable.  Lunascape works with Firefox add-ons and Internet Explorer plugins. There is a wizard that will import your add-ons and favorites and you can install more additional add-on. I highly recommend Lunascape to everyone.
Cheers
