What is the difference between Lyx editor and LaTex? What distinctive features are in Lyx editor that are not in other text / word processing software? Who is Lyx editor design for? How best can novice customize Lyx editor for own use? in learning to use Lyx Editor, what are paramount?
Lyx Editor and LaTex any Difference?
Lyx is a sub layer process wherein LaTex is being encoded. Both are not comparable with each other as they do not represent the same approach or use. It is like comparing a pencil with paper. Lyx is used for LaTex system to be compiled with so that the result may be seen. In addition, Lyx produces LaTex files or you may convert the LaText file to Lyx. For tutorials from various sites, click this link LyxTutorials.
