I have installed a new online game on my laptop and I when I want to log in this Client error appear and close my game. On my laptop I have another 2 online games and they are running smoothly. Why I can’t log in on my Client ? Is this game with error or my PC ?
Thanks !
Mabinogi: Client.exe – Application Error
The exception unknown software exception (0x0000005) occurred in the application at location 0x017f536c.
Please move restoration activity through step by step approach –
1. Check if any antivirus or anti malware is blocking your program or not
2. The try to re-launch once again. Actually such error is very common for unlicensed or pirated games/tools; I believe you are using a valid and legal version.
3. Refer to self help manual provided with game itself. Go through their instructions
4. If problem still persists, please reach to vendor support for help, only they can provide you with help in this case.
If you installed Mabinogi but you can’t play the game, check the system requirements again and verify that your computer meets those requirements. Mabinogi supports 64-bit Windows 7, Windows 8.x, and Windows 10. It requires 2.5 GHz Intel Core i3 or faster processor, 4 GB RAM, Microsoft DirectX 9.0c-compatible video card (NVIDIA GeForce 8600GT or better), 10 GB free space, sound card, and broadband internet connection.
Mabinogi
If there’s no problem with compatibility, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select Mabinogi among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install Mabinogi back. If the problem continues, download the latest Mabinogi client again. Make sure you have an admin account when installing the game.
1....
