Mac avi to windows avi how to convert? Is there any converter with functions like edit, download video, burn video, play video etc you can use if you need? It should contain support both video and audio data that allows simultaneous audio-with-video playback.
Here download this file if you are using Mac and this one if you are using Windows.
Step by step Guide for Mac.
1. Load MOV videos to the MOV to AVI converter Mac.
Go to the file menu and click the load media file option. Pop up will appear and choose your selected video.
2. Select "AVI" as the output.
3. Start converting.
Guide if you are using Windows.
1. Load MOV Files to Windows Converter Ultimate.
2. Set AV format as the output format.
3. Start Converting MOV to AVI.
