Mac combine vob files together
HI everyone,
I am using Mac operating system. I like to join vob files together. So that I can enjoy DVD rip movies without interruption. I am using Aimersoft video editor for Mac. But it doesn't work properly sometimes. Is there any other video editor software for Mac combine vob files together ?
By, Joseph
Best Answer by Au Summers
Answered By 0 points N/A #190153
Hello Joseph,
Boilsoft VOB Joiner for Mac provides a  good solution for Mac users to join,merge and combine small VOB files into a single VOB so that you can watch your videos without interruption and good quality.Also please check the step  by step procedure for using the Boil soft which may help you.
Step 1. Install the Boilsoft  video joiner
Step 2. Import the VOB files which you want to combine into Boilsoft VOB joiner
Step 3. Then you can tick "Merge".
Step 4. After you go through above steps press " OK" to combine the files in a few minutes you will get the combined single VOB file.
Sandy
Answered By 0 points N/A #190152
Hello Joseph,
Going by your question, I assume you already have the VOB files ready. Aimersoft should do the trick, but if you keep encountering problems with it, you might want to try Handbrake for Mac to convert your VOB files to .AVI, .MP4 or whatever your preferred format is.
1. Launch Handbrake and choose the files you want converted.
2. Once you've loaded the files, you will see the following:
3. Chose the destination where you want your converted file saved.
4. Start converting.
Hope this helps.
Murakami Wyatt
