MAC error in system program detected
I am getting lots of System program problem detected error on my desktop. If I Report the problem nothing happens and I still get these errors. Does anyone have any idea about this error ? Why I have this kind of errors ?
Thank you experts !
System program problem detected.
Do you want to report the problem now?
Answered By 590495 points N/A #178005
Yes, of course, and it is to be expected. After an error such as this happens and you click on the “Report problem” button to send a report to Apple about the issue, it’s normal to still get the error if you repeat the same task. Because sending a report to the developer will only give them a bug to fix for their next update release but will not eventually fix the problem on your computer.
To possibly fix the problem you encountered, you need to update your operating system because normally, Apple releases operating system updates periodically and these updates fixes bugs and improves system performance. To check if there is an available update for your operating system, click on the Apple menu and select Software Update. On the next screen, you will see if there is an available update for your operating system.
If an update is available, click Install to install the update and possibly fix the error you encountered. If the error is from a program you previously installed, try reinstalling it or maybe update it to the latest version. But if the error is from a program that comes pre-installed with Mac OS X, reinstalling the operating system will probably fix the problem.
