Steps on adding MAC Machines to Active Directory
Mac machines add Active directory.How to add mac machines to AD.
What is the steps to add iMac running Mac OS X 10.6
Thank you
Best Answer by gkhan
Answered By 5 points N/A #97129
Do not continue if you are unsure of what to do. Do not try to download or install illegal or manipulated software. Visit www.brothersoft.com and search for the AD you were looking for. And then download and install it to your computer.
Answered By 0 points N/A #97131
Important to Remember
Install Windows Server 2003 domain system with Active Directory.you must have the domain admin account(with new adding rights).
After that follow these steps .
The first step is to have your information network as domain name, your account or accounts with admin rights to add domain account. Here, you assume your domain name isMydomain. My admin account named Myaccount.
  1. To make the setup, we use the Directory Utility application. This application is located in / Application / Utilities / Directory Utility.app
  2. Select the Services tab
  3. In this section, the protocol connection will be displayed. We will connect to the network through Active Directory. So, we click the box Active Directory. Then a window will be shown to establish the parameters necessary.
  4. In this window, set the parameters on the domain as shown above. Active Directory Domain is the domain name. Here, your domain name isMydomain. Computer ID is the name of the computer shown in the network. Here, his name is kulMacBook.
  5. If you have experience in setting up the network, you click the Show Advanced Options to set additional parameters improve the other. Here, you keep all the default settings.
  6. After Mandatory parameters needed, click Bind to connect.
  7. The dialog box, you will be asked to enter account information or an account with admin rights to connect your domain. Then click OK.
