Mac Mini Vs iMAC which is better to buy?
I am looking to buy a MAC but confused on which to select
How to decide which is better
Cost is not an issue as far as i can buy one at 3,000$
Thanks
Thanks
Since you are not conserned about the pricing as far as it is less than $3000, you better go for the iMac. Since Mac mini is an entry level PC for home without a display (you need to connect it to a monitor or a TV), whereas iMac is a solid all-in-one personal computer that will satisfy all your business and home computing needs. iMac can also be used as an entertainment device as it comes with a widescreen HD display and high quality speakers.
It depends upon your requirements. You need to understand the needs and for what purpose do you want the PC. You need to look at your wallet as well. If you are ready to pay a good amount, more than 3000 dollars then you need to choose iMac. However, if you want it in small size then in that case you can opt for the iMac mini. You can connect it with TV or monitor if required. With latest requirement I will prefer iMac mini as we can take it anywhere and has all features that Mac PC has. There is only little difference between the two.
Waters Magner
