Mac Operating System X IPSec connection
Hi all,
Just recently purchased ASA 5505 to take the place of our old firewall/vpn device. After a massive learning curve I have pretty much figured out what I am doing, I can´t figure out the Mac VPN connection.
When trying to connect using the built in Mac Operating System X IPSec connection I receive the following error message: A configuration error occurred. Make sure you settings are correct and try again. I know for a fact that all the following information is correct
host, pre-shared key, group name, and user name. I can´t even get to the screen where I have to give a password
If I use the VPN with Windows it is fine.
Looking for some answers please.
