Mac OS X TextEdit Error
Lately, I get this error every time I open Mac's text edit program. At first, I just ignored it but after a few times of seeing it, I got frustrated and had to fix the error. The error is below.
The folder named 'autosave' is in is the "Library" folder. The Sharing and Permissions of the "Library" folder is "Administrator: Read and Write. Everyone: No Access."
I am logged in as the administrator so if I am reading correctly, I should have complete access and permission. (also the autosave folder has the permissions of "System: read and Write, Everyone: no access. For some reason this text is opaque, meaning I cant change it.
In order to solve this issue go to same location in the problem user and you will red minus sign on the folder. That means that you don't have access to it.
Now follow these steps:
From here you can change the access privileges of the given folder or file. I hope that you find the solution to the problem.
Peter Franklin
The biggest the problem, the simplest could be a solution!
Your auto-save option is currently on. You shall try to save files manually (“Ctrl+S” option).
Now to stop auto-saving files, go to home folder then to Library and delete the "Auto-save Information" folder which should fix your problem.
Don’t forget to save manually else you may not able to recover the file again.
For this particularly problem you can follow the following easy steps. With this you will not encounter the same problem again.
You need first to ad yourself (your username) to the Autosave List of the folder:
1. Go to <your_hard_drive>=><Users>=><your_username>=>”Library”=> “Autosave information”
2. From here get info on the Autosave Information folder clicking on the lock icon.
3. Authethicate and add your <username> to the list.
4. Now add Read & Write permission.
This will fix your problem.
Thanks,
Aabel
