I am using Mac OSX Leopard 10.5.5. I am trying to install Unity ISIS. However, this installation error appeared stating that the installation is failed. Are there any requirements for me to finish the installation?
Please guide me on this matter.
Thank you!
Here's the screenshot of the installation error:
Error:
Install Failed
The following install step failed: run preflight script for Avid ISIS Client. Contract the software manufacturer for assistance
Mac OSX Leopard 10.5.5 Unity ISIS Installation Failed
This error is generally occurred when an previous Unity ISIS client version has previously been installed on the system, and where the standard ISIS uninstall process via Applications/Avid_Uninstallers/AvidUnityISIS/AvidUninstaller.app has left ISIS software bits remaining on the system. These software remainders do not let a successful install of the ISIS 1.5 client and as a result cause the error.
If the standard ISIS uninstall process fails to entirely wash out the system of all previous ISIS client software elements, then the following manual process should be utilized:
To manually Uninstall ISIS client and Reinstall on Leopard (OSX 10.5.5.)
If there then Delete the AvidUnity ISIS folder from Applications
Navigate to Library/Startupitems and remove AvidUnityISIS folder
Navigate to Library/Receipts and remove AvidUnityISIS.pkg
Restart
try reinstalling ISIS 1.5 client software
If you are still not able to reinstall ISIS 1.5 client software, call Avid Customer Support at 800-800-2843 for more help.
