Mac OSx ppt converter PDF
Hello
You can use Microsoft PowerPoint for Mac. Follow these instructions:
– Click on File then on Print
– Check Scale to fit paper checkbox
– Click on bottom left dropdown menu and select PDF
– Click on first option "Save as PDF", select name for your file and click Save button
– Now you'll see some warnings just click Yes and you have converted file
I hope I helped
Hi Evelyndnell
There is no need to install any other app to convert PPT to PDF on Mac
As you are having 10.6 OSX, you can open the desired PPT file, then go to File > Print
Then at the bottom, select save as PDF under the PDF button
Now to select any text , you can open the created PDF and preview them on your MacBook.
Hope this solves your problem
Thanks
Bennie
