Is Mac software appointment scheduling not compatible with Lion?
Hi.
I just installed MEMOTXT Scheduler which sends SMS messages for appointment reminders.
The program just shows a white screen then eventually crashes.
I installed it on my iMac with OSx Mountain Lion.
Is this Mac software appointment scheduling not compatible with Mountain Lion?
Best Answer by Randolph Brownlow
Answered By 50 points N/A #148041
You should give this software a try Appointment scheduler Mac os x.
Answered By 5 points N/A #148042
Hello Dudley
Unfortunately MEMOTXT Scheduler is not compatible with Mac. It is only for Windows.
That is why the error shows up after which the software eventually crashes.
In this case, I suggest you use an online scheduler. It is easier and you don't have to worry about compatibility.
My recommendations for you are Acuity Scheduling which is very ease to use and definitely for your requirements.
I hope you will find this information useful.
Randolph
