[Macbook] Thinking of applying thermal paste on heatsink to resolve display issue
10 points
Posted on - 01/30/2012
On my MacBook Pro 17", the screen shows some unwanted lines. Its graphics card is not GeForce 8600.
Will it be alright if I apply thermal paste on the graphic heat sink? Would that remove the unwanted lines? If yes, how do I get to the heat sink? If that doesn't work, then is there another alternative to fix the problem?
Thanks ahead for the help.
