What are the distinctions between the MacDraft PE and MacDraft Pro? Are there any differences from AutoCad? Please tell me the dissimilarities of the three in terms of graphic illustrations and more. Detailed answers are most welcome. Thanks.
Is Macdraft pe a reliable graphic design software?
Hello, Roger Garrison
First of all, Macdraft pe and Macdraft pro is just the same. The difference of it are the features of the software. I will make a graph for you to understand and have some idea.
Features                    Macdraft Pro       MacDraft PE
Tool Palette                      Yes          Yes
Linked dimensions                 Yes          No
Accessory Palette                  Yes          No
Dimension Palette                 Yes          Yes
Custom Dimension Palette           Yes          No
Resize Palette                    Yes          Yes
Layers                          Yes        Max of 5 only
Custom Fill Colors & Patterns         Yes          Yes
Import/Export Images              Yes          Yes
AutoCAD DWG/DXF Import & Export    Yes           No
Integrated Database               Yes          No
Report Function                    Yes          No
Limited Paper Size Up to A3(UK)/B(U)   No          Yes
Printed Manual                    Yes          No
In short, it is good to use Macdraft Pro than MacDraft PE because you can use all the features of it and you are not limited. But in the Macdraft PE, you are limited only.
