Macro coding for PowerPoint VBA remove whitespace
Hello Friends,
I have a plenty of MS PowerPoint presentations, which I am cleaning up, most of the files is having additional white spaces, as those files were converted from other formats, please provide me macro coding for PowerPoint VBA remove whitespace. So that my work will be easier.
Thanks & Regards,
Christopher B. Pyles
Answered By 0 points N/A #128283
Please be reminded that macro coding doesn't work on Microsoft Office PowerPoint 2007, but using VBA, you can be able to create and edit macros. In order to do this, click Office button and then PowerPoint Options. You have to activate the Show Developer Tab in Ribbon in Popular category. This will Enable the Developer tab so that you can able to set your PowerPoint in PowerPoint Macro-Enabled Presentation file type. In viewing your file, do this in Macros via Developer tab. You will need to give your macro a name. The command shall be "c:<file name.file type>". That is giving a name and saving it. Now you can be able to edit your PowerPoint via macro coding file type.
