What are the most effective ways of detecting macro viruses and is there a software for macro virus removal that is applicable for all types of Operating System. If your computer is infected by this, can it harm and corrupt the files saved on both RAM and ROM?
Macro virus removal and detection
Good day Mr. David,
Macro viruses are easy to create but very hard to detect. Using a scanner it is still very hard to recognize which macro is a virus and which macro is not. It differentiates the two sides by it's activity. Here;s some points for you MACRO VIRUSES. You can also download protection to your pc. Any software for antivirus can protect you from macro viruses. Watch this tutorial.Â
Also try to avoid unnecessary emails, web sites, messages and stuff that goes direct to your pc and are very hard to identify. This will keep your pc safe including your RAM and ROM.
Cheers,
