Cohen Allen
10 points
Posted on - 05/29/2012
There is an error when using a Dreamweaver MX template. It would say "Nested editable regions" although there are no such regions. Dreamweaver also refuses to update the pages that are linked.
Do you have any idea what is wrong with this?
Thank you for the assistance.
There is an error at line 4, column 138 ( absolute position 267) of ' ' ) Nested editable regions.
OK
Macromedia Dreamweaver MX template error
If this is the first time you encounter this problem on your program, try restarting your computer then try it again. See if it works the next time. If it doesn’t, try doing a clean installation of the program again to eliminate possible corrupted files in your installation. Uninstall Macromedia Dreamweaver first then restart the computer. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use disk utility applications like PC Tools Performance Toolkit, or Norton Utilities. Install Macromedia Dreamweaver again after this. This should work now since this is a fresh installation. But if it still doesn’t work, you should now check the program you are coding. You should check every link carefully to avoid any wrong data from being overlooked.
You may also try upgrading your current version of Dreamweaver. Install Adobe Dreamweaver CS6. This version works on Windows XP Service Pack 2 and later, Windows Vista Home Premium, Business, Ultimate, Enterprise Service Pack 1, and Windows 7. This version also supports Mac OS X 10.6 and 10.7. To download Adobe Dreamweaver CS6, visit Adobe here.
