Macromedia Flash CS5 Runtime Shared Library Error Appear
I am user of Flash CS5 use this software for creating animation. Last day I create one animation after creating animation. I try to create interactivity with that animation for creating this interactivity.
I write some script, and when I compile that script then I receive below error after receiving this error I close Flash CS5 and again try but same error appear. All detail of error is given below for your understating.
Your content will not stream. Runtime Shared Library (RSL) preloading will require all of your content to download before the first frame will play.
To prevent this you can change the Runtime Shared Library. Library Settings in the Advanced ActionScript 3.0 Settings dialogs which can be raised from the publish Settings dialog.
The Runtime Shared Libraries being preloaded are:
TextLayout_1.0.0.595.swz for TLF Text
Don’t show again.
                 OK
