Evan Dunn
Posted on - 05/30/2012
Hello there,
I have upgraded to office 2007 recently. Previously I was using office 2003, had set quite a few Macros. Do I have to revise macros/application code for Office 2007 ribbon interface?
Macros/application code for Office 2007 ribbon interface
Hi Evan
There is minimal need to change macros or application code because of the new ribbon interface of Office 2007. However, because some commands have changed, check Differences in the 2007 Office system to determine whether you need to revise macros or application code. Please refer to the below mentioned URL to check for the differences in the MS Office 2007 version:
https://technet.microsoft.com/en-us/library/cc179054.aspx
Hope this helps!
Arseno
