MadCap Flare V6-The Given key was not present in the directory
Hello I am using Madcap flare for text editing staffs. I want to check several files but I got this error, the error message below.
When I am going to Files-> Source Control -> Project -> Check in All, I got this error.
How can I resolve this?
MadCap Flare V6
The given key was not present in the dictionary
Best Answer by Tony clever
Answered By 20 points N/A #111643
Hi friend,
When you are going to check files from Files-> Source Control -> Project -> Check in All you got an error. That comes because you have problem with arranging file in Madcap flare for text editing staffs. “The given key was not present in the dictionary”that means the file that you are searching is not present in Files-> Source Control -> Project -> that directory.
To solve this problem you have to avoid trying to check all file at a time. You have to check those files individually or you can check them on similar groups from the Pending Check-Ins panel.
Answered By 5 points N/A #111644
You can resolve this to reset the setting from the command prompt to remove the connected possible problem, and then try to make a new project. Occasionally there corrupted files from the project setting can source the harms if it’s possible only or attempt to reboot your operating system to safe mode. Attempt to make a different user account, and then this maybe can benefit to isolate user profile exploitation linked causes or simply attempt to disabling Add-in Manager or Tools. Try to scan the machine if there infected files from viruses or maybe spyware simply check on that if it’s possible.
Ben
