Magento popular search terms configuration
I want to configure my magenta store. I want to configure Magneto popular search terms if anyone has any idea about it then help me.
Hi, In Magneto Search terms are listed in a “tag cloud” format. The link to the Popular Search Terms page is located in the footer of your store. By default, Popular Search Terms is enabled as a SEO tool but has no direct connection to the catalog search process. To configure Popular Search Terms:
Go to your admin panel, select system then Configuration. In the Configuration panel select catalog. then do the following two steps Expand the Search Engine Optimizations section. Set Popular Search Terms to “Enable.” After all this Click the Save Config button to save the setting.
