Magic Bullets Denoiser Sample Noise Error
I am testing Magic Bullet's Denoiser when I encountered the error below. This appears on a frame of a clip under a layer of video which includes three way color corrector. I don't know how to fix it since when I clicked on the OK button of the error message, the same warning will re-appear. Can someone help? Thanks.
MB Denoiser
Unable to Sample noise from current frame. Please select another frame and click "SAMPLE".
OK
Best Answer by
Answered By 590495 points N/A #120731
The message “Unable to Sample noise from current frame” is a warning that will pop up on your screen whenever Magic Bullet Denoiser bumps into a frame where the program cannot properly detect the noise. According to Red Giant, the developer of Magic Bullet Denoiser, this issue is actually a bug someplace in the database.
It has the tendency to happen when your timeline has multiple clips and or maybe you are using multiple plug-ins. It can be fixed by changing the sample current frame to another. So, in case you are working on a video and you accidentally bump into this problem, go back to the controls and click Sample Current Frame to change the frame where Magic Bullet Denoiser was working on.
