Magnet Makes The Samsung Series 5 Hybrid PC On Top
Transformers and ultrabooks go together nowadays. With the new release of Samsung Series 5 Hybrid PC, it unveiled something unique among others. Series 5 Hybrid PC is the Magneto of the Transformers as it uses magnets to connect the tablet to the keyboard dock.
If you don't feel like using the keyboard, then you can just pull it and just use the tablet since it's touchscreen. However, I'm just quite concern how the magnets work for this. If i unintentionally bumped into the tablet, will it release the magnets just like that? Also, will the S Pen work on this model?
Is this a PC or a tablet? A little confuse.
Help me out guys.
Answered By 0 points N/A #132422
Samsung Series 5 Hybrid PC is a 11-inch Windows 8 tablet with a keyboard dock attachments that converts it into a laptop. It makes a connection to its base magnetically rather than clicking into a dock connector.
The simple use of magnets to dock the screen and keyboard makes this device stand out among competitors in terms of simplicity and usability. Don't ever doubt it's magnetic abilities. The slate won't slip out of its cradle without any effort on the part of the user.
And yes, it will come with the same S-Pen and S-Memo software used on the Galaxy Note 10.1 (but modified for Windows). It even has a long battery life of eight to ten hours has a pair of 2- and 8-megapixel cameras.
