I have this almost perfect mail connector. It has basic functions such as sending and receiving mails and synchronizing the read and sent messages. But I found a little problem on this connector. It does not allow me to forward any of my mails. Other thing, every time I try to reply to my messages, it only sends a blank page. What do you think is the problem of my mail connector?
Mail connector inconsistency error sending messages
Hallo Lucille Griffin,
You should have mentioned the kind of connector you are using so as to make it easier to find the context in which to help you troubleshoot the problem you are having with it, because different connectors will have different configurations which in this case might be the ones causing the problems.
You will need to check connector's send permissions, if they are assigned or not. If they are not assigned, then you will have to assign them. The send connector has a security principal that will establish a session, and determine the types of header information which will be send in the email that you have forwarded. So it is possible that the security principal you are using does not allow delivering the message in the forwarded mail and thus you will have to change that.
Hope this helps.
__
Regards
Mahesh Babu
