The main activities of Skype for internet user
Sometimes Skype creates problem to use. Voice chat create problem hugely in Asia and to the other country as well.
In the Asia region internet user's are facing some problems to use many software, as for example Skype. When you are facing any problem in Skype for voice calling or video chatting, at first you have to think about your internet speed. Sometimes it is very difficult to sign in Skype. In that case, you must fill your user name and password carefully.
Then press enter. Wait for a little while. If you see, you can't sign into Skype still now, then restart your operating system. After a little while you will try to sign in. If it is not possible for you, then go to the Skype website and contact with the administrative support. If you feel any problem during voice chat, you will check your Skype credit.Â
Although you have enough Skype credit, then notice your internet speed. If the speed then low contacts with your server administration to speed up your connection. I think if you have enough Skype credit and your internet connection is very fast, you would not be facing any problem.
Hi Mahali,
The main problem in Asia is the Internet speed. Here, speed is very slow.
I am also from Asia and I faced this problem at the time of voice chat.
Very simple, increase your Internet speed.
After then, you will not face this problem.
I think the reason why most of the Asian users are experiencing this is because the client software is not configured properly. If you are presently experiencing the same problem, try installing the latest version of the client.
After installing Skype, configure it then install other devices that you need to use like the webcam. You should also configure your computer’s microphone to make sure it is working and to adjust its volume as well. And the most important part is your Skype ID and password.
If you don’t have an ID yet, you need to create an account first to get your ID and password.
You will not be able to use Skype if you don’t have an ID to login.
