Main differences between C and C++
Hi! I have a Question for Programmers.  I want to know bit detail on both C and C++. What are the main differences between C and C++. Why we prefer C++ instead of C? Does it effect on the coding also? Is it possible to use C and C++ in TURBO C?
Best Answer by Ian Richardson
Answered By 0 points N/A #85815
Good Question 🙂
Data is secured in C++ unlike C. So C++ is a more secure language than C.
C ++ is a middle-level language where as C comes in low-level language
Approach type in programming is different.
C++ uses the bottom-up approach while C uses top-down approach.
C is function oriented while C++ is object oriented language.
C++ unlike C supports function overloading  concept.
Function inside structures can be used in C++ unlike C.
Input output functions that are standard differ in both the languages.
We prefer C++ instead of C as it is more advanced language than C with lots of features and mainly because it has a feature for data protection known as Encapsulation.
Ya it is possible to use C and C++ in Turbo C. Just that C program is to be saved with extension “  “ .C” and C++ program with extension “ .C++”
Answered By 0 points N/A #85816
<Nice Question:>
The main difference between C and C++ is that In C we can declare only variables in a structure where as in case of C++ we can declare both data variables and member functions. That is why it is much prefer to use C++ than the C language.
And some C programs are not executed in C++.
example:
I have a statement in C like,
int boot;
/* boot is a variable of type int (** boot not identifier in C) */
The same statement,
int boot;
is written in C++, It gives an error "redeclaration of type 'boot';
On the other hand, I can say yes to the last question because Turbo C is an obsolete version of C compiler. Do not confuse of the compiler with a programming language (C++).
