Yesterday I could not login to main WordPress login session in chrome. I try many times but failed. When I try the same thing in Mozilla it worked out. I am still confused what could be the reason for this? Just curious to know.
Main WordPress login failure in chrome
This problem can be caused by different issues, which may include:
Connectivity of the internet has been lost.
Temporarily unavailability of the website.
The Domain Name Server (DNS) cannot be reached.
The Domain Name Server (DNS) is not listed for the website's domain.
There could be a typing error in the address.
Try to check whether there is an HTTPS address. When you see it, click “Tools”, then “Internet Options”, and the click “Advanced”. This is to be sure that the SSL and TLS protocols are enabled under the security section.
Try to update your Chrome by doing the following:
On the browser toolbar, click the Chrome menu.
Choose Update Google Chrome.
There will be a confirmation dialog that will appear, click Restart. The browser will restart but will save the opened tabs and reopen them and apply the update automatically after restarting.
Hi, Danny I Sanders
It is very common failure in Logging in on WordPress when you use Chrome. There are some forums that has steps and procedures to avoid this failure. Some users have discussed about it. You can check it below. I can suggest you some good forums, which are listed below:
Hope it helps you a lot.
Thanks and More powers.
