Major Dissimilarities In The InformaticaPowerMart And PowerCenter
What is the difference between theInformaticaPowerMart and PowerCenter?What are the additional features in the PowerCenter which are not available in the PowerMart?
PowerMart is used to create the local repository which can configure only one server whereas the PowerCenter is used to create the global repository through which we can configure multiple servers.
PowerMart does not allow the sharing of metadata across partition data and repositories while PowerCenter does.
PowerCenter has other PowerConnect options (for PeopleSoft, IBM MQSeries, IBM DB2, Siebel, SAP R/3, etc.) which are not available in the Powermart.
Notifications
