Hello experts,
To make banner use what format? What is the file extension that best compatible when designing and rendering banners? I am also confused on what application should I use to get the best format because i had a problem before by saving a file format because of the wrong application that I use.
I hope you can help me.
GIF format is the best for making banner design. Some program do not save file as gif format. To have this saving format you use Photoshop and photo-scape. Photo-scape is good for preparing a animated Benner.
Finally, Try to use vector art format rather than raster format if it is possible. Others saving properties may be needed to maintain when you are going to print the banner.
There are many tools available for creating banners that you can use on your website or on your Facebook. One of it is the Banner Maker Pro which you can purchase for $39.99. the service offers unlimited banner making. You can save the file as GIF, JPG or PNG. Another one is the Banner Design Studio that is compatible with Windows 7. It will help you make GIF or animated flash banners with just some clicks for the price of $49.95.
You can also use the Microsoft Publisher that has built-in templates including banners. Scribes is also one of the powerful software that can be use for making banners. And Adobe In Design. Most of it are not free so you really have to purchase one to enjoy the unlimited features.
