noemibwhite
10 points
Posted on - 09/07/2012
I need to urgently SIM reader internet support.
Every time I connect to the internet I am unable to make calls and vice versa.
I tried searching for a software to do the same but could not find any.
Is there any way I can work around that?
Make calls and connect to internet through SIM reader internet support?
I see that you are facing a problem with your SIM reader. You need to install the right software to use the SIM reader. There are many software available in the market but you have to choose the right software according to your requirements. Some software have specific requirements so make sure you check them before you use them. The reliable software for SIM reader are listed below:
1. GSM SIM reader – You can download it here – https://sourceforge.net/projects/simreader/. It is a very efficient software. It is easy to use and uses very less memory.
See the screenshot below:
2. USB SIM card reader – You can download it here – http://usb-sim-card-reader.software.informer.com/3.0/. See the screenshot below:
3. Mobile SIM card reader – You can get it here
