Monitor a mobile phone using my own cell phone
Hey Erni Fitri!
If you want to monitor another mobile phone using your own cell phone, you have to modify the Bluetooth settings on each phone. Just search on the internet for a Bluetooth software tool that will help you to do that. It is a Java file that will help you modify the other cell phone. You can change the settings of other cell phone, read messages, dial a call, take a picture; in fact you can handle the other cell phone completely with your cell phone. Make sure that both mobiles are Bluetooth enable and Bluetooth of both of the mobiles are set to on.
Thanks
Yes, it is possible to monitor every activity done on the mobile phone. I’ll list below some of the best tools you can use to help you monitor the activities happening within the mobile phone.
