Make Flash cs5 create component as desired
70 points
Posted on - 01/24/2013
Hello Flashers,
Is it possible to make flash cs5 create component that are not part from the known shapes ? for example parallelogram and triangle.
I do not want to make it manually by assembling lines, instead I am looking for a method allowing to do so automatically, I would only have to specify the base of any shape.
