Make gif transitions between 2 pictures
How to make gif transitions between 2 pictures? I also want to keep different colors to both pictures. Please guide me about the option of gif transitions in Photoshop.
Hey,
Following is the step by step instructions. As you have not mentioned which Photoshop version are you using. So, consider reading your user manual to find similar buttons which are going to be used in this post.
Thanks
Hi Daniel Nicholass,
Follow these steps:
Open Photoshop > open two pictures (picture1 and picture2) > copy picture2 to picture1 file. In picture1 file, there will be a new layer which contain picture2 > go to menu Windows > Animation > In frame 1, you have picture1 visible, picture2 invisible. In frame 2, you have picture1 invisible, picture2 visible > go to menu File > Save for Web and Devices > leave default values, just give your file a name and choose location to save your file.
Hope this helps
