Make Grafitti on Your Computer
Hi Erni,
There are a lot of available free software for download that you can make graffiti with the design that you desire anytime you want. One basic and easy to use is WINDOWS PAINT .Â
– Click Start
– Go to Accessories
– Click Paint
Explore, the tools are friendly and easy to use. But disadvantage in using this program is that it has limited features only. One best software and most popular and common is Adobe Photoshop. Which is the main software I use too all the time. The tools are friendly, there are many options, many features and colors, effects, so you can manipulate easily your desired graffiti graphics any time you want.Â
We can start on making graffiti by creating your own graffiti font. You need to make a graffiti for each letter. You have to remember that a usually .
You have to decide whether the style you make for your graffiti is distinctly sharp corners or very fat rounded corners, when you make your decision then you can start to for .Now you can scan your graffiti to your computers to 200 dpi, you can save it as GIF file.
You need to have the font design software for your graffiti, you can use it to refine or edit your graffiti alphabet and symbols, when your satisfied with the design and style of your graffiti that is the time to that you can now use on your windows applications.
