Hi expert,
I need a help. I want to make a high resolution handset icon.
Is there specific software to make a high resolution icon?
If you know please send the download link.
And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages.
Make a high resolution handset icon
Hello Eric,
It seems you want to make high resolution handset icons. Creating high resolution icons depends mostly on the model and applications of your handset. A launcher icon is the graphic that represents the application.
Launcher icons are used by Launcher applications and appear on the user’s Home screen. Launcher icons can also be used to represent shortcuts into your application.
You can visit the following link for more information.
https://material.io/guidelines/style/icons.html
I hope this helps.
