To make Limit clause as I typically do in MySQL
Hi Seth,
There is an equivalent SQL clause for LIMIT on FireBird. As far as I know the support start on FireBird 1.0.3. Using the FIRST keyword you can mimic the LIMIT clause in MySQL. There is also a keyword called SKIP to skip rows you don't want to show.
Here is a sample of how to do it:
SELECT FIRST 10 column1, column2, column3, column4 from TABLE1
To use SKIP with FIRST clause:
SELECT FIRST 10 SKIP 20 column1, column2, column3, column4 from TABLE1
Rows 21-30 will be displayed when the above query is executed.
I hope it helps.
Hello Seth,
There is a LIMIT clause in Firebird which is much similar to that of MySQL's LIMIT syntax.
This is very useful in situations where you bother to run the database cursor over multiple requests and very useful when you want the database to return back the most relevant result, over a large result set sometimes
This is working fine in Firebird 1.0.3.
SELECT FIRST x [SKIP y] … [rest of query]
This syntax will return 'x' number rows of result from the query, and optionally skip first 'y' number of rows.
Here is an example you might want to take a close look, it returns back row 21-30 from a query
SELECT FIRST 10 SKIP 20 column1, column2, column3 FROM foo
Recall the similar syntax or statement used in MySQL:
SELECT column1, column2, column3 FROM foo LIMIT 10, 20
Hope you will get something out of this.
