Make my DVD-dual player work properly
Can you please give me some tips to make my DVD-dual player work properly? I really had no problem of it before. This is the first time I encountered this, I mean I have used Videostudio for ample of years already yet this time it failed.
I even needed to use Corel website just to check if they are compatible using the Corel Website. The discs looks perfectly fine while in the process of burning. But as I play the discs it will just play for only half a minute. How can I make it work?
As I remember I already experienced burning a dual-layer disc. I think the only thing that seems never working is Videostudio.
Can you please help me with these?
